Re: CA18DET Dyno/Coilpack Help Needed
From Brisbane
Thanks Guys,
What plug model/numbers are you running?
Cheers
Jason
Posted on: 2006/7/19 3:21
From Adelaide. SA
I had the same problem with mine, I just ran the cheapest plug that i could find (about$2.20 ea) and havnt had any trouble since. Cheers. Adam.
Posted on: 2006/7/18 23:25
From brisbane
Hi mate
I've had coilpack trouble at various times too. I chose to run a colder plug and gap them down a bit and this has helped significantly.
Matty
Posted on: 2006/7/18 21:14
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Brisbane
Hey guys,
Got my CA18DET Coupe dynoed and got 170rwhp on 8 psi.
Had heaps of problems with blowing up coil packs.
I am running a Wolf 3D computer, Bosch ignitors and standard coilpacks.
Tried different spark plugs on dyno and had similar problems.
Any ideas what causes this or how it can be fixed????
It was suggested that I run PFR7B sparkplugs and see if this would fix problem.
Anyone overcome the same problem?
Posted on: 2006/7/17 23:31
