Re: Late block A10???
ddgonzal wrote:
What about the A10 engine in the 1976 Datsun 100A (E10 Cherry)? Would that have the new-style block?
It would seem logical that the 1976 model 100A would use the later design block, but the chances that one would be found in Australia, then converted to rear drive for use in a Datsun 1000 would seem to be pretty slim.
With the realisation that this is a taller block than the 'regular' A10's that were included in this group, it would seem most likely that someone has re-labeled this engine to simplify some of those irritating bereaurocratic issues that accompany engine swaps.
Posted on: 2006/8/18 21:28
Love your Datsun.
Treat it well.
From Adelaide, South Australia
Does the finish on A10 on the block still look cast ?
It should be easy to tell.
Posted on: 2006/8/18 16:37
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From Perth WA
Well i think i solved the mystery!
It has a bigger gap from top of timing case to the deck of the block then the other A10s.
Plus where would i get a motor out of a Cherry in WA? I know of 2!
Posted on: 2006/8/18 12:38
Chris...
From Freo
Looks like a 1000 flywheel though.. the rear face is as tall ts the ringear... ???
Posted on: 2006/8/17 7:08
Wikipedia
Posted on: 2006/8/17 5:24
From Canberra. ACT
Yeah good idea dodgeman but hey are saying people would do something as terrible as that tut! tut! tut!
Posted on: 2006/8/17 5:09
Look at the front of the engines & compare the distance between the top of the timing case & the top of the block, [head gasket face] & compare with the 'regular' A10's
If this one has a bigger gap, then it has a longer stroke & would therefore be a re-stamped fraud.
Posted on: 2006/8/16 21:34
Love your Datsun.
Treat it well.
The distributor in that position indicates a 1974-or-newer engine.
Which Datsuns came with an A10 after 1973? There you will find the answer.
Posted on: 2006/8/16 17:33
Just looks like a late A-10-12 block does it have the emissions tap on the right side of the enigne between the front of the engine and the first exhaust port ?
Posted on: 2006/8/16 17:08
Albert Einstein
From Perth
That clutch looks bigger then 160mm too
Keep rubbing....... might be an A12 restamped for rego
Posted on: 2006/8/16 14:48
