Re: Needed stanza brake caliper
From Lakes Entrance, Victoria, Australia
Are the Stanza brake boosters the same as the 200B/180B brake boosters?
Posted on: 2006/8/25 6:17
From Brisbane
yes late model stanza and late model 200b are the same
Posted on: 2006/8/24 13:39
From Canberra
I have a pair im not using now.
PM me if your still interested
Posted on: 2006/8/24 9:45
From Adelaide, Australia
If it helps im sure 200b girlocks fit, also try Mitsi Scorpians and many other aussie assembled cars will interchange, just grab the pair because piston sizes can vary.
Posted on: 2006/8/24 9:19
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
yep disaster. tryed the easyout tool.
Posted on: 2006/8/24 9:16
Not likely, they get pretty god damn stuck.
This happened to me when i did stanza front end on my partners car, disaster!
Just a tip, when cracking bleeders or other small pain in the arse bolts, always tighten first then undo, just helps the thread find its way without biting into the alloy and getting stuck.
Posted on: 2006/8/23 14:47
IPRA Build
From Sydney.au
if where it snapped off is hollow you can use a reverse thread tool which screws in backwards and unscrews the stuck in thread. then you can just get a new nipple and screw it in!
Posted on: 2006/8/23 14:41
Hi i need a left hand front stanza brake caliper. As the bleeder screw snaped of in mine and tryed to get it out and it stuffed the whole thing.
Need it ASAP so give me a ring 0416780603 or pm or email, chrismccallum@optusnet.com.au
Thanks Chris.
Posted on: 2006/8/23 13:45
