Re: Dwel Angel & Points gap?
From SE Melbourne
Your welcome.
All the info came from a Datsun Sunny workshop manual - you could pick up one one ebay - or download this one that I have text recognised as well.
Datsun Sunny manual
Posted on: 2006/9/18 2:36
Mildman, Datsunless
Quite a regular
From South-Africa Pretoria
Thank You 4 the information!its useful to me.Set the timing,and dwel and hopefuly the points wil last a bit longer.I have a A14 Nissan ute jear 2005 Mod.The people here in SA say that the A14 Nissan ute is going of the market,they not going to make it any more?There is plenty of spares for A12 A14 here in SA,as the A14 Nissan is the same as A12 Datsun.Maybe you must try and inport a 5speed box?
Posted on: 2006/9/17 23:14
From SE Melbourne
Valve clearance (hot):
Inlet 0.35 mm
Exhaust 0.35 mrn
Cold set to .25mm
Here's some other stuff you might ask for...
Spark plug type:
N.G.K. . . . . . . . . . . BPSES, BP4E, BP6ES, BP7ES
....... Hitachi L46PW, L47PW, L45PW, L44PW
........................ Spark plug gap 0.8-0.9 mm
. . . . . . . . . . . . . . . . . Spark plug tightening torque 20 Nm
............ Contact breaker point gap 0.45-0.55 mm
Engine idle speed:
.................. Manual transmission 650 rpm
................ Automatic transmission 750 rpm
.......... *Compression pressure (nominal) 1245 kPa
........... Compression pressure (minimum) 980 kPa
Fan belt deflection 8-12 mrn
Enjoy - jealous of the 5 speed too - a little rare in Australia.
Posted on: 2006/9/13 23:46
Mildman, Datsunless
Quite a regular
Thanx for the information! Im in SA,and the people at Nissan tels me,that the old nissan sentra box shape disy fits in my A15 with out any mods,its a electronic one. Im not sure,what should the intake and out specs be of the valve clearence? The DAt now have a 5speed box and a A12 dif with the A15.
Posted on: 2006/9/13 18:48
Distributor dwell angle .49-55 deg
Ignition timing at idle speed 7 deg btdc in neutral
That's the same for A14 & A15
If you use a dwell angle meter [prefered] then set the points to 49 degrees. As the rubbing block on the cam wears, the dwell will move through the range towards 55 degrees & your timing will slowly retard a little.
If you start at 55 degrees, you are already at the wrong end of the scale & it will quickly go out of spec.
I reset mine last night & it came out at 48 degrees. Close enough,....... but always recheck the timing whenever you adjust or replace the points.
Posted on: 2006/9/12 9:40
Love your Datsun.
Treat it well.
From Strand, South Africa
thanks.
LOL, I've done almost the same thing. rotated the sparkplug leads one point to the left or right(my memory sucks at this time of the morning) and got a new understanding why pre-ignition is also called ping. Made the same sound as a submarine hehe. Luckely no engines were damgaged in the making of the sound.
Posted on: 2006/9/12 9:01
From SE Melbourne
Nah....it's only how long the electrical connection is made between the spark plug and the coil - 1 degree is nothing. I was trying to start my car with the timing 180 out....fire in the intake rather than the exhaust...that was a little bad.
Timing I'd say is worse to get wrong than dwell.
Posted on: 2006/9/12 7:57
Mildman, Datsunless
Will there be any catastrophic effects if your dwell angle is 58 degrees? or am I just a tad paranoid?
Posted on: 2006/9/12 7:50
From SE Melbourne
Posted on: 2006/9/12 2:51
Mildman, Datsunless
Quite a regular
Hi,what should the gap be on the disys points,is the A14 & A15 the same.What should
the dwel angel be on a A15,and the timing.Could anyone please help me?
Thanks CCG
Posted on: 2006/9/11 23:26
