Re: 120y rear sway bars
From southern sydney "the shire"
i want it lo loose rear end traction but not the front. i just want something that will make it slide easily
Posted on: 2006/12/15 13:34
From Brisbane, Australia
a rear swaybar will help keep the inside front wheel on the ground, but it may lift the inside rear. In fact, it WILL lift the inside rear if you get the 18mm bar! I know, I had one... That means no traction out of corners with the standard diff. Let me rephrase that - no DRIVE at all out of corners until the rear wheel caomes back down!
even if it doesn't actually lift the inside rear wheel, it will unweight it resulting in less traction when cornering.
It will also increase the tendancy of the car to oversteer. I would upgrade the front bar or spring rate at the same time as you fit the rear bar. I would go for the smaller of those 2 bars.
Posted on: 2006/12/15 11:25
yeh ive got 2" blocks to go in and some lovell springs too. ill see how it goes with them in it
Posted on: 2006/12/15 10:25
From Burbank, CA
hehe that's what i'm thinking, I've never lifted the front wheel. maybe needs some bushings if it's that easy.
Posted on: 2006/12/15 8:24
|||\ 81 KPB310 /|||
From Springwood NSW, Formerly Tas.
thats what im after. i have the leafs in the back. i feel like it will roll over before it will slide out. also the front wheel comes off the road when cornering (hard) how can i fix that?
same.. ive had that wheel up a few times, motorkhanas are one place lol
Posted on: 2006/12/15 5:19
1978 120y Coupe.
From Burbank, CA
lowering the car helps too, lowering the car and inch or 2 can do wonders.
stiffening the rear end could help.
Leaf spring rear end experts ??
Posted on: 2006/12/14 4:09
|||\ 81 KPB310 /|||
Posted on: 2006/12/14 2:28
From Burbank, CA
The rear swaybar is only for the leaf spring 120Y's i believe.
they compensate for body roll, so do you have excessive body roll?
Posted on: 2006/12/13 17:16
|||\ 81 KPB310 /|||
Addco makes a 1" sway bar for the front and 5/8" for the rear. Hope that helps you.
Posted on: 2006/12/13 13:18
From Adelaide, Australia
Not really worth running, not even necessary for the track, some good oil shocks and a tad stiffer leafpack will be enough.
Posted on: 2006/12/13 11:01
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
