(1) 2 3 4 ... 8 »
Re: Building the A-series???
From Perth Western Australia
Hey grease monkey,
I'm doing about the same as you in terms of building up a streetable but hot A series - I'm using the A14 as a base with standard heads - going the twin 36 webber option.
I'm also trying to work out a cam compression, valve springs and all the specs for the build, which is how i stumbled apon this thread.
So onto your question,
Yella Terra here in aus +(613) 9555 5522
(www.yellaterra.com.au) make roller rockers for the a-series in a variety of ratios I'm told - hope this help ya source some.
Good luck with the build
Posted on: 2007/5/9 15:08
From Vancouver WA. U.S.A.
Any one have any suggestions?
Posted on: 2007/3/26 20:00
BE sure to check out my coupe build thread and feel free to leave comments good or bad.
[url=http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=36107&fo
I have a company that I can use really good prices I just need to give them some specs, i am also A dealer for Yella Terra rocker arms now and I thought I read some where that they make a-sereis roller rockers, but i havent found any thing yet
Posted on: 2007/3/25 21:38
From Selah, Washington
Give these guys a call.
DELTA CAM
They are in Tacoma. This is where I got mine. Cheap too! The Grind I got is what they call "D9" I can not recall the specs off the top of my head.
Less than $80.00
Posted on: 2007/3/25 21:07
Well i got an A-15 today so I will start the build for the coupe, The body work is almost complete just need to decide on colors and purchase paint. I was wondering about the roller rockers for the a-15 and what I need to lighting on the valve train?
Posted on: 2007/3/25 18:18
I was wondering if some one can give me some cam specs and I will have a custom one ground
I finally got the pics to upload so here you go
Posted on: 2007/2/28 11:22
Also I cant find any casting marks on the head.
But if it has double valve springs and oval intake ports and a heart shaped looking comustion chamber than its a GX head?
Posted on: 2007/2/27 15:43
well i cant get the pic to load but the intakes are oval
Posted on: 2007/2/23 1:31
I found another but iam still interested in yours what were you wanting for it?
Posted on: 2007/2/16 4:56
Greasemonkey, you found another A15? or were you wanting mine?
Mike
Posted on: 2007/2/16 1:43
(1) 2 3 4 ... 8 »
