Re: 1200 rallycoupe freeze plug sizes
From Albuquerque NM, USA
thanks,
I learned something new today.
now it's time to drink beer
Posted on: 2007/8/3 15:36
From Coondle, WA Australia
kelmo
to ensure that you post in the same thread, use the reply to button at the top of the post that you want to reply to (usually the last one). Dont use the button at the very top that says
Post new Thread. That will do as it says and start another thread, rather than reply.
hope that gives you some more direction.
cheers
Posted on: 2007/8/3 13:19
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
the freeze (welch) plug's sizes
cam brng 44mm part# 11019-32201 qty 1
core hole 50mm part# 11021-F5400 qty 1
core hole 35mm part# 00933-1355A qty 3
front water pipe part# 21045-18000 is no longer available and the catalogue does not give the size....stinkers.
these are part #'s for a12 USA designation
hope it helps.
Also not sure if this posted to your original thread....still trying to figure all this out.
Kelmo
Posted on: 2007/8/3 11:53
NISMO
Nissan Impresses Sluts More Often
