Re: can someone tell me???
From Adelaide, Australia
Could even be the split pin that holds the pads in.
Goodluck matey I'll be up early out on anzac hwy waving you boys on!!
Posted on: 2007/9/28 7:45
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Adelaide. SA
Yeah im gonna check the calipers before the bay to birdwood.
Cheers
Posted on: 2007/9/28 7:43
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
Its not a wheel bearing loose is it Adam? Also could be strut insert a little loose or caliper even.
Posted on: 2007/9/28 7:08
IPRA Build
B110 drum-brake wheels
B110 diske-brake wheels
...are the same.
Later B210 wheels are different, they have a little more room inside (in diameter, not offset).
Posted on: 2007/9/27 23:34
From Adelaide. SA
I have just put stock 1200 disc brakes on the front of my 1200 sedan, my question is are drum brake rims and disc brake 12" rims the same?? When I apply the brakes I get a small knocking sound from the front (caliper hitting on rim) Are the rims the same or do I have to find some other rims??
Cheers. Adam.
Posted on: 2007/9/27 22:56
Peter Brock
