Browsing this Thread:
1 Anonymous Users
Re: 12" wheels on 180 struts towers? |
From Geelong, Vic
200b rotor and stanza calipers? pretty sure they are stanza rotors
drove on 12s today for the first time since i got the car and damn was it the most unsafe ive ever felt in my car
they do spin really easy though which is about the only good thing about them
Posted on: 2007/11/14 12:20
From Wallan, Vic, Aus
Okay I've done it, as follows:
200b Struts
200b Rotors
Late Stanza Girlock Calipers
About 6 - 8 mm Spacer Plate
And a grotty little 12" rim.
My struts are 240k ones, but ive been told they are the same as 200b. But the backing plate behind where the rotor goes is differnt, the 240k one goes around more. So i just removed it. 200b one will be fine.
Posted on: 2007/11/13 8:51
yeah, I meant the whole front end? Remember when i came up to your place and my car had that huge negitive camber, because I have a 240K front end? Well I want to change it to try and get rid of that negitive camber, as when i drive down the highway, the car keeps pulling side to side the whole way. So if that is a stanza rotor as well, then what front end would you suggest, the car has an L20B in it. The prvious owner says it had 200b brakes. He must be wrong
Posted on: 2007/11/5 1:06
From Geelong, Vic
nah it will be a stanza rotor as well i would think
difference between 200b and 180b struts or the whole front end? main difference in struts is the different caliper spacing
Posted on: 2007/11/4 23:05
ah okay Pigdog, so its a stanza caliper your saying? I found out that it is a 200B rotor. But what about the front ends, is there a difference between 180 and 200?
Posted on: 2007/11/4 11:32
From Geelong, Vic
stanza
Posted on: 2007/11/4 6:48
Posted on: 2007/11/4 6:07
hmm, still trying to figure out what is what. Can someone tell me what differences there are between a 200b front end and a 180b front end. Also what differences there are between a 200b front rotor compared to a 180b rotor, are they the same? The caliper I have that fits a 12" over it is a girlock, it has Datsun written on it, then in smaller writing next to the datsun, is "120 00". Does any one know what those calipers are off? I had a look at a 200B again and its not the same caliper, still havnt been able to look at a 180b. They are the calipers i got with the car, but as I said im still trying to figure out weather its 200 or 180 stuff (As in rotor and strut). The centre of the rotor sticks out a fair bit, which is why with a spacer plate the wheel just clears.
Anyone with any info please do tell. Thanks
Posted on: 2007/11/4 5:44
i like my cross drilled 200b rotors and corona calipers... thanks pigdog. i like my stopping power. and the 14's that go along with that
Posted on: 2007/11/4 2:46
From Geelong, Vic
if 12s fit with spacers, then im guessing you have the pissy little sunny or 180b brakes.....id be willing to trust them with my life
Posted on: 2007/11/3 9:00
