Re: Fuel line fittings
From SE Melbourne
This is the flare that tool makes.
What sort of flare/bead does your tool make Ange?
Posted on: 2007/10/5 12:54
Mildman, Datsunless
From Melbourne AUS
something like that. as long as it gives you the correct flare.
that one looks like it gives you the trumpet style flare for brake lines.
you need something to make your fuel line look like the end of a barb fitting.
if that makes any sense
Posted on: 2007/10/5 6:35
1973 B110 A12
From SE Melbourne
You mean something like this Ange?
Posted on: 2007/10/4 15:14
Mildman, Datsunless
From Melbourne AUS
i used a cheap flaring tool. it did the job.
havent had a problem in nearly 2 years.
i would reccomend flaring.
Posted on: 2007/10/4 8:13
1973 B110 A12
From Melbourne Vic
i can guarantee that if you use the right clamps it will not leak weather there is a flare or not. I have no flares on a few of my fuel line ends and they are no worries. i'm not saying its a waste of time flaring but i have not found it necessary in my experience with both SR and CA turbo motors. the base preasure is 28psi (i think) and i think it raises 1psi per psi of boost so my lines have seen 46 psi with no worries.
Posted on: 2007/10/4 7:06
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Perth W.A
i just rang an enzed about one of those tools and he ways saying for the cost of the tool and the amount of times you would use it in a hobby environment, it wouldn't be worth the purchase, and they can do the whole car for me for $50 for those flares. $5 each end isn't bad.
Posted on: 2007/10/4 6:27
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From SE Melbourne
I look into it a bit further - haven't heard back from the shop in Oakleigh yet either...
Posted on: 2007/10/4 4:29
Mildman, Datsunless
From Melbourne, Australia
well....
if its just round with no flare no matter how tight you turn that hose clamp you can usually still spin the hose on the fuel line... and if you can do that it is surely going to leak at some stage
and the tighter you do them up the sooner the hose cracks up and leaks as well
i guesstimated the length of metal fuel line i needed when i bought mine and got them to flare the ends when i bought it... before i started bending and getting it stuck under the car
plumbers do have the best tools.. i had a plumber do those flared ends for me... any houses being built in the area where you might find a handy plumber?
Posted on: 2007/10/4 4:22
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From SE Melbourne
hmm....you don't think EFI hose clamps are going to be enough Mike?
Posted on: 2007/10/4 4:17
Mildman, Datsunless
would definatley be flaring it one way or another, dont just put it on straight tube
you might not be driving it long before it burns to the ground......
Posted on: 2007/10/4 3:52
1200 Coupe Rallycar
(1) 2 3 »
