Re: 56A box, how can i tell if it's a four or five sp?
From Burpengary
hahaha, i didn't expect it to be, just a little annoyed at myself. i had no idea about anything to do with anything when i bought the ute so i took the guys word that it was a 5 sp. :(
i just wanted it for highway use.
Posted on: 2007/11/21 9:18
From Coondle, WA Australia
Yeah looks like all the 4 speeds that i have in the shed, and not like the 5 speed that i have.
Id go with the four speed option, sorry its not instant retirement stuff...
Posted on: 2007/11/21 3:42
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Burpengary
thats ok, it was just in the back of a ute i bought and just wantin to make sure it wasn't worth anything. who knows, i coulda put it on ebay for $25k or something...
thanks guys for your help
Posted on: 2007/11/20 13:08
From north brissy
judging by what b310gx said its a 4 speed
Posted on: 2007/11/20 12:12
I was going to post the pictures for you but they are way too big, so I'll do these links instead,
Link 1
Link 2
It looks to me like a good ole floorspeed.
What do others think.
Posted on: 2007/11/20 12:11
Love your Datsun.
Treat it well.
From Burpengary
ok, i know its a 56A because it says it on the side, that's the only indentifying mark on it.
here is some pics
Help!
Posted on: 2007/11/20 11:44
This is my 56A five speed. Note that the main gearbox case is a pressure die casting while the extention housing is a gravity [sand] casting which is fatter than the four speed one as both reverse & first gear are located in there.
Note also the position of the reverse switch & this is a solid guide to the 5 speed variant.
Both the 4 & 5 speed versions share the same main transmission case & it will have the base model of 56A clearly visible in large characters on the right side. The external ribbing on the case is a dead giveaway to the 56 series as well.
Another picture. Fat arse five speed.
Posted on: 2007/11/20 10:56
Love your Datsun.
Treat it well.
From NZ
I've got each of these. Front housing is the same for both.
5-speed
-Sandwich plate differs - oil drain plug screws up into this from the bottom.
-Tail Housing - bulkier to encase 1st gear (as well as reverse). As mentioned above the reverse switch position differs from 4 speed.
4-speed
-Tail housing - oil drain plug screws into this from the back.
Posted on: 2007/11/20 10:01
From sydney australia
Check the position of the reversing light switch, it's a dead give away, & the 56A appears to be cast on different parts of the front housing, though that could just be a production change for 4 speeds.
Posted on: 2007/11/20 9:47
I put together a Comparison photo. Hope it helps:
56-series 4-speed vs. 5-speed Comparo
Posted on: 2007/11/20 8:35
