Re: Tailshaft for CA conversion
From Adelaide
If you get stuck, we can supply a completly new 3inch tailsharft with re-buildable unis to any length for about $550.
Posted on: 2007/11/29 13:00
From Sydney, Australia
BLUE is the color. Difference between local and imported 180B??
I think blue ones were local because I found one at the first wreckers I went to. Dunno. I was told by an expert to find a blue one..and it worked. Didn't do too much more research. In a light car, the wheels are more likely to spin than we are to twist and break a tailshaft. Worn out Uni joints will also cause most breakages.
ps. I still had to have mine shortened. And I'm using the S13 box.
Posted on: 2007/11/29 12:50
From Brisbane
i have a shortened stanza, in my coupe, standard flange suits bw diff, don't use a ca tailshaft they aren't rebuidable
Posted on: 2007/11/29 11:37
From Mandurah, Western Australia
Your on the money with the price and this is why I left this till last.
So a 180B Tail Shaft will fit the standard CA18 Manual gearbox?
Had a look in the manual but it does not cover the tailshaft. What does the BLUE Donate
Posted on: 2007/11/29 11:29
you need to find a front yoke with rebuildable uni joints, and the rear to suit your diff.
I used a BLUE 180B tailshaft for the front bit and tailshaft, The tailshaft guy put new back uni-joint and flange on to suit the BW.
Full custom can cost up to $700..no kidding. Tht's using all new parts. Consider that the worst case scenario when getting pricing.
Posted on: 2007/11/29 11:06
Looking around Perth for a s13 CA18 Manual tailshaft at the moment. Have yet to speak with anyone who has one.
Is the front yoke on a CA18 shaft the same as the s13 SR20 manual tailshaft??? It is going to be cut up and shortened anyway and have found plenty of Sr20 tailshafts.
Posted on: 2007/11/29 10:47
