Re: A14s not performing can you help ?
From Burbank, CA
i suspect the fuel is a bit more octane than you need... lower octane may yield more power unless you have the compression to take advantage of high octane.
Posted on: 2007/12/4 19:54
|||\ 81 KPB310 /|||
From The garage, NZ
that timing sounds pretty low. for that octane fuel anyway.
Standard is 10 degrees in North American A12's and 7 degrees in aussie and nz if i recal correctly.
Posted on: 2007/12/4 19:53
Valve clearance: What your cam vendor recommends. For stock camshaft it is 0.35mm intake and 0.35mm exhaust HOT.
only get 51 kw at 5600 rpm & 101 nm
That sounds about right for RWHP "at the wheels" for an A14. Stock ratings for the 2007 A14 are 47kw & 97 n-m -- "at the flywheel".
Posted on: 2007/12/4 18:27
A14s re-run results better (any ideas for more kW )
Not too shy to talk
From RSA
I have a a14s motor 276 cam , 36 dcd weber , std branches , powerflow 40mm pipe rockers set hot in-30 exh-35 point gap 45 plug gap 65 timing set at 8 deg running on 102.6 octane fuel but only get 51 kw at 5600 rpm & 104 nm what are the settings supposed to be and +- kw & torque please help ??
Added tnt 4-1 branch + 45mm pipe set timing @ 11 deg rocker set inlet-35 exh-40 cold sets now running 52.5kW @ 5559 rpm
110 Nm @ 3921 rpm
Posted on: 2007/12/4 15:40
