Browsing this Thread:
1 Anonymous Users
Re: BOOSTER |
From Nyngan, nsw Australia
OO i wasn't to sure, I thourgh it was just abit high.....Cheeers
Posted on: 2008/3/16 8:31
Re: BOOSTER |
From Canberra
thats not the clutch cylinder up top, its a remote resevoir to clear the manifold.
Posted on: 2008/3/16 7:56
Re: BOOSTER |
Yes now i can see the differient in sizes,
looking at your pic's there i see the clutch cylinder is up top, is it able to be attached to original pedal where the cable came out of?
Posted on: 2008/3/16 7:26
Re: BOOSTER |
From Canberra
from the looks of this the PBR master cylinder would probably hit the inlet manifold. If its the master cylinder I'm thinking of it has another cylinder on the engine side of the normal one with the brake line coming out at right angles towards the plenum. I had to remove mine to fit a 4age manifold, the normal 120y booster/datsun mc gives you a lot more room.
Posted on: 2008/3/16 6:11
Re: BOOSTER |
o ok thanks for the tip
Posted on: 2008/3/16 2:28
Re: BOOSTER |
From Sydney, Australia
it's normally the clutch master cylinder that hits on the back of the plenum.
Posted on: 2008/3/16 0:24
'71 Green 1200 Sedan CA18DET Project 99.98% complete '71 White 1200 Sedan 20,000mi + A14T (twin 40DCOE 30/70 cam, extractors) Website: http://www.shoeys.com
BOOSTER |
Hey Fellas..... I have a 200B booster with the square plastic tank on top, Is that to big when fitting CA18DET into the bay of my 1200,
Posted on: 2008/3/16 0:18
