Re: Throttle linkage
www.swmotorsport.com.au - best to call them directly though.
Posted on: 2008/3/29 12:39
From Sydney
Grrr - redline sale are slow to respond...
Whats SWM?
Posted on: 2008/3/25 8:15
From Sydney
Thanks all! Trying redline sales....
Had my last one welded on - but it was a bit of a pain to remove. Trying to make this setup a bit neater..
Cheers!
Posted on: 2008/3/22 3:21
if you're after the actual bit the throttle cable attaches to, the easiest way is to pull one off a stock carby and weld it to an arm peice that suits the shaft you are using ...
if its the whole lot you're after redline do pretty much all the other bits
Posted on: 2008/3/21 22:18
Try redline, or SWM
Posted on: 2008/3/21 16:12
Throttle linkage
From Sydney
Im looking for a throttle linkage piece similar to the one in the middle of this photo..
Anyone know where to buy them??
Posted on: 2008/3/21 12:10
