Re: SR20DET in a 1200 or B310. Overkill ??
From Perth
The DE pistons have higher Compression - that is the only reason I will be running them.
The second evolution of this engine should run 10:1 comp with some forged copies of the European NA SR pistons.
Posted on: 2008/4/15 23:57
From sydney
I have a sr20de in my 1200 post slapped a turbo on the side runs 11.01 120mph down the track not bad for a little datto all standed no mods
Posted on: 2008/4/15 21:33
datsun 1200 post 2 door seden
From malta
whats best about de piston??? is it compression??? or material????
Posted on: 2008/4/15 18:24
From Darwin NT
its just like that a6. why??? because he can what for? no one knows but he did it because he wanted to. do what you want but make sure you plan it out first so then you have an idea on the cost of it and you may find a few little bits that might be a big problem.
Posted on: 2008/4/15 7:42
current project 4x4 patrol...
From Malaysia
Damn...it affected my IQ until i read your last sentence...thanks for the "p.s" notice man....
Posted on: 2008/4/15 4:49
Do whatever you want. Build the car for yourself. So what if it is so powerful that you can't take nan to the shops in case she has a heart attack. Sure people will say it's overkill. But deep down they will be jelous. And rightly so. If you have to sacrifice your nans longivity in order to make this dream come true then so be it. These are the things that we have to do.
If Gary Myers can put 2 superchargers on a mustang and drive it then a SR20DET is nothing in a 1200. If god didn;t want 2 superchargers bolted together then he wouldn't have given us the billet alloy to make such components. I say he's a pussy for not bolting 3 blowers together.
p.s. ignore this whole statement as taking it seriously may affect your IQ...
Posted on: 2008/4/15 2:24
From Perth
Hi Guys,
Using the DET block to make life easier as the oil & water galleries in the block are ready to go. Also the DET has oil squirters already in place. All of this can be achieved with the DE block but requires drilling etc..... I picked up a Good DET for $800, with a stuffed crank (someone used the wrong bolts for the flywhhel and stuffed the threads). Also picked up a DE bottom end which has already been stripped and the pistons and crank will be going into the DET.
The DE Cams are also being used as they have more lift than the DET cams, but without increasing the duration. The Tomei ones have more lift again and will be used down the track.
With the turbo, I will be using the same turbo as was on the FJ - a 2876r Garrett jobbie - worked well with the restrictor. Runs the smaller .63 (?) rear housing and the .7 front hosuing.
Posted on: 2008/4/15 0:55
From malta
so a standard turbo will be the ideal since u want a low rev when the turbo will work. the bigger the turbo will mean more revs needed for the turbo to make effect
Posted on: 2008/4/14 13:00
From sydney australia
Mark, Why not try the SR20DE+T route, where you just get a DE & put a turbo on it, like you're 1st option. It seems you don't need to run a lot of boost to make these work making heaps of torque, & this should work in nicely with the restrictor plate. DE's seem to be pretty cheap to buy, & i bet a lot of the drift guys would have stock exhaust manifolds they'd have taken off sitting around. Running lower boost would also lower the engine bay temperature & give things a longer life. I know the DET engines have some things different to the DE, but i think the cranks are the same.
Posted on: 2008/4/14 11:27
From Perth
Have been running the FJ up until now. The SR is a lighter proposition for the race car, also easier to get parts for than the FJ.
The new motor will be somewhat of a hybrid also......
Version 1 - SR20DET with standard NA Pistons and NA Cams.
Version 2 - SR20DET with forged European NA Pistons (10:1) and Tomei Pons Cams.
Keep in mind, we have to run a restrictor also which means peak power is at around 5,800 rpm so the normal high rev issues of an SR are not a concern for me.
We will be running approx 18-20 psi boost but everything will happen low in the rev range - bit like a tractor engine.
Posted on: 2008/4/14 5:45
(1) 2 3 4 »
