Re: datsun 1200 ute weight and engine weight questions
I keep forgetting a 120Y is near the same weight as a 1200. Unfortunately in my country all B210s are very heavy with HD suspension, 50-pound bumpers, and A14 engines and 60 or 63 series transmissions.
Posted on: 2013/6/25 4:57
lets just say you can carry an a-series up the street when dry
Posted on: 2013/6/25 4:44
From Brisbane
I think you would be surprised mate, a lot of that weight comes from going from a little 1.2lt A-series motor & little box to a 1.8lt engine, twincam head, turbo, bigger brakes, full 3" exhaust, intercooler and the extra piping etc.
Also that 1060kg is including driver so you're talking maybe 970kg... which means that all those mods have only added 175kg which is the same amount you'd expect the same mods to add to (eg) a 1200.
A 1200 will still be ahead but not by much!!
Posted on: 2010/10/9 23:55
Yes, 1060 kg is fairly heavy B210. It's why the B110/B120 is preferred at only 760 kg.
Posted on: 2010/10/9 21:52
From Brisbane
I'm thinking that the friend I build for my 120Y will be somewhat more minimalist.
Posted on: 2010/10/9 10:45
From Brisbane
Bumping up an old thread I came across in a search.
For interest I thought I would add that my '78 120Y 4dr is 1060kg with:
CA18DET & 5 speed
3" exhaust
FMIC (not huge, not tiny)
stock diff
15" steelies
two 14" steel spares/tyres in the boot
all fluids including half a tank of fuel
Posted on: 2010/10/8 1:42
From Las Vegas USA
My coupe is 800KG, I still run all the street gear (I like the look) but that is only about 20 kilos.......most of the gain was the roll cage. The 1.75 inch tube .125 thick with 3 door bars each side and a couple of extra diagonals tend to add up. Not to mention the 280ZX struts and brakes are quite a bit heavier than the stock struts.
Last year I added up what it would take to drop 50-75 kilos and it would be several hundred bucks.
Tom
Posted on: 2008/4/19 22:17
From South Africa
Mine 810.45Kg
A15 motor (turbo charged)
W58 Supra gearbox.
Alloy wheels all round 15"
3\4 fueltank .
Posted on: 2008/4/19 16:09
From Mudgee, NSW
My ute has an sr20de, skyline stumpy 5 speed with r31 diff, had half tank of fuel at the time and weighed in at 920kgs, with 2 big tool boxes in the back....
So im gonna take a guess and say its about 870kgs, with no spare tyre.
Posted on: 2008/4/18 23:46
200b - SR20det project....
A looooooong term project
Not too shy to talk
From Brisbane
my ute with a15 and 60 series 5 speed tipped the scales at the dump to 890kg, half tank of fuel, me, the boy and some green waste included so about 750kg sounds fair.
Posted on: 2008/4/18 22:05
