Re: urgent help needed with ignition (1000)
Quite a regular
From Radelaide (south)
Well its all sorted I got a mobile mechanic round and he got her goin not 100% sure what the go was as I wasnt there at the time, I think a mixture of things though. At least I have a car again yay!!!!
Posted on: 2008/5/16 8:34
A good way to identify if your condensor is stuffed is to check the contact sufrace of the breaker points. If it is a light smokey grey then it is all good. If it is a bluish colour then the condensor is crook. Also check that the points are correctly gapped at 18thou or 0.45mm. Also with new points there is a coating on the contact face that requires rubbing off prior to fitment (clipping the points on your T shirt and a quick rub does the trick) and a little bit of high temp grease where the rubbing block runs on the dizzy lobe goes a long way to the longevity of the points. Other than that not much else can go wrong with a dist or coil. It always pays to make sure your dist has 12V going to it. The coil may never have been at fault.
Posted on: 2008/5/15 14:10
Quite a regular
Got a new condensor and still nothing so now ive decided bugger it and got a mechanic coming round to look at it, hopefully he can sort it out!!!!
Posted on: 2008/5/15 13:29
The rubbing block on new points tends to wear very quickly at first & this can really mess with the ignition function, so along with ensuring that you have a new condenser, make sure that you still have the correct point gap.
Once all of this is established, you will need to re-check the timing as it changes with the points wearing.
Posted on: 2008/5/14 15:28
Love your Datsun.
Treat it well.
Quite a regular
No worries cheers mate, I only got tune a few weeks ago (points etc..) but couldnt hurt to replace em too just incase.
Heres hoping this works I hate having to bludge lifts to and from work
Posted on: 2008/5/14 13:48
From Perth WA
very well could be. They usualy fry points when their rooted too.
Wouldnt hurt to do a full tune up while your at this stage. New points, capasiter(condencer), plugs etc.
ALWAYS renew your capasiter whenever you do points. Just get a 1200 capasiter from your parts shop, same thing! Or anything that looks like the one you have(wire length etc), their all the same pretty much.
Posted on: 2008/5/14 13:38
Chris...
Quite a regular
I was just havin a look on the net, I reckon its the condensor ill get a pic
EDIT:
This is pretty much what it looks like
Posted on: 2008/5/14 13:30
From Adelaide, Australia
Ahh ok, I've got no idea then, sorry mate.
Posted on: 2008/5/14 13:26
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Quite a regular
Nah its like a cylinder thing that comes off the + side by a wire then earths to the bracket its about the size of the top part of your finger
Posted on: 2008/5/14 13:24
You mean the ballast resistor? (little white ceramic thing on the side of the coil) I though dodgeman said it shouldn't have one? Just ask for a 1200 one, I think they are all the same for datsun models as Im using one from a 1200 in my stanza.
Posted on: 2008/5/14 13:13
IPRA Build
