I think they're too big - certainly for street applications.
I had problems with a 16mm rear bar on a street 1200 - it would easily lift the inside completely off the ground when cornering moderately hard. The 20mm rear bar is about double the rate of a 16mm bar, but as its mounted to the spring instead of the chassis may not actually work as effectively. But even if its only half as effective in that position, I still think its too stiff.
Anyone who has upgraded to a 120Y front bar on their 1200 will tell you it makes a huge difference to the car, and that's only a 63% increase in anti-roll rate over standard. A 25mm bar is 2.5times greater than the increase in anti-roll you'd get by going to a 120Y bar!!! I don't think any street tyre is going to be able to handle that - you'll simply overcome their grip co-efficient, unless you drop back to almost standard 1200 spring rates. In which case you'll get alot of pitching under brakes unless you set up some anti-dive geometry in the front end.
I think we've got a case of "if big is good, bigger must be better" going on here.
For comparison, I used 20mm front and 16mm rear bars (both of which are about half the rate of 25 and 20mm) on my previous track car, which handled like this:
BathurstMtCottonand that's with a big heavy L series in the front, and a locked diff so it didn't matter if the inside rear got light (it was actually a bonus). The same is not true for an LSD, let alone an open diff. Lift an inside wheel in one of them and you have basically no drive. You have to remember the sway bar lifts the inside wheel with as much force as is resists roll on the outside wheel. Do you need stiffer sway bars than this? particularly ones that are twice as stiff?
I recently picked up a whiteline rear bar 2nd hand which is 18mm, and would need something like a 22mm front bar to balance that out. And I'm very hesitant to try those bars on my race car, let alone a road car! These are massive changes we're talking about here.
i hope they work for you, but from my experience I think its totally overboard.
