Re: 1200 ute coilovers
i have been told to fit in s13 silvia coilovers and brakes, then upgrade the brake set up to something bigger and better.
Posted on: 2008/7/8 10:29
From Geelong, Vic
do you want commodore stuff for the 5 stud conversion or just for the brakes?
if just for the brakes then do the vs caliper and magna disc on 180b strut, shorten strut to suit 240z inserts and then fit some DIY coilovers from datsport or maddat
Posted on: 2008/7/7 13:39
but will still need to use commodore hub assembley tho rite? thats the main thing that i am worried about. the discs and pads etc will come later. can u get s13 struts to bolt onto a commodore hub? has to pass engineering in tas.
Posted on: 2008/7/7 12:48
From Sydney, Australia
vs ss = vl turbo etc.
Using the Commo rotor is a waste of time, Just get some undrilled Verada rotors, and use the Commo calipers.
Although I've heard of dudes using commo calipers and rotors and hubs with S13 struts. Not sure much about it though.
Posted on: 2008/7/7 12:34
1200 ute coilovers
hey all, im trying to sort out my suspension set up for my project ute.
i want to run coilovers in the front but i want to have holden vs ss commodore disc brake set up on the bottom. just wondering if anyone has attempted this b4. everything that i am looking at doing so far hasnt seem to have been done but im sure that someone has done this b4. any info would be great. Cheers brenno
Posted on: 2008/7/7 12:19
