Re: Header results
From Toowoomba, Qld
Thanks guys.
Posted on: 2008/7/12 13:49
Re: Header results
well since the GX exhaust manifold uses 1-1/2 exhaust pipe, the drivability should be better than the larger extractors (tubular headers). But the extractors should make more high RPM power.
Posted on: 2008/7/12 5:34
Re: Header results
From Tamworth , NSW
not exactly solid, but it as been bandied around that the gx headers flow just as well if not better than aftermarket headers.
Posted on: 2008/7/11 23:50
Header results
From Toowoomba, Qld
Has anyone got any solid info on the performance/driveability of GX Headers with a good system behind it, compared to a set of extractors, also with a good system.
Posted on: 2008/7/11 23:47
