Re: what's a good way to update dash?
From Adelaide, SA
i have put an aftermarket tacho into stock coupe dash seems to be a popular way of having acurate readings but keeping with stock look
Posted on: 2008/7/17 7:27
From Adelaide, Australia
In my opinion a remoulded 1200 dashpad and coupe facia is pretty hard to beat.
Im holding my tongue regarding those alternate dashes...
Posted on: 2008/7/16 9:28
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From SE Melbourne
I'm the same...
1 x old school
1 x not old school
I just thought it was a little weird to say if you want to alter the Datsun1200 then you don't deserve to own one...
Posted on: 2008/7/16 6:31
Mildman, Datsunless
From Brisvegas, oz
well it looks like there is alot of opinions on whats good and whats not..in my case i like both, thats why i have more than one 1200 one is the old school style with the a series and one all the new gear with the ca.
Posted on: 2008/7/16 4:56
www.camerasplus.com.au
From SE Melbourne
if u want a trick dash that looks the #### with all the gauges get another vehicle...and is 100% datsun.
Does putting a CA18DET count as a trick engine? Would the quote be - if you want to put a CA18DET into a Datsun - get another vehicle...
Posted on: 2008/7/16 0:22
Mildman, Datsunless
From Jimboomba s/e QLD
its all up to the owner of the car i suppose some people like the stock look and others like the modified look as usaual there will always be a difference of opinion and taste
Posted on: 2008/7/15 8:58
82 1200 ute ca18det project still building
frankthedolphintrainer
i might need you to keep some detailed pics of your dash set up and heater/demister hopefully they will get me to pull my finger out and re-do mine
Posted on: 2008/7/15 8:45
From Brisbane
it appears as if some people like having their good old dattos but wanna modern them up a lil too much. if u want a trick dash that looks the #### with all the gauges get another vehicle. if u want simple and real clean looking keep your original dash, cover in new fabric and chuck a bit of paint on it. thats what i did with mine and it looks badass and is 100% datsun.
Posted on: 2008/7/15 8:43
From The garage, NZ
why would you want a car that was designed in the late 60's to look like it came out of the factory in the 90's?? Sure you get other gauges but theres always the option of adding period correct gauges in places that wont be in your face and still do the job. ####e puzzles me sometimes...
Posted on: 2008/7/14 21:46
From Brisvegas, oz
i plan to make a steel frame from scratch, and modify the original heater box to work for the demister
Posted on: 2008/7/14 21:29
(1) 2 3 »
