Re: FS coupe tacho, 7/8th master cylinder, stanza strut conversion stuff
From Geelong, Vic
PMs replied
all stuff now sold pending payment
thanks for the interest
Posted on: 2008/9/3 12:42
pm sent
Posted on: 2008/9/3 6:39
From Geelong, Vic
tacho sold
stanza stuff and master cylinder may be sold also if no one else is quick
Posted on: 2008/9/3 6:11
From Oberon NSW {Bathurst}
PM Sent
Posted on: 2008/9/3 4:51
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
Quite a regular
From Brisbane
I take that tacho off your hands Nick. PM Sent.
Posted on: 2008/9/3 4:23
From Geelong, Vic
got a few random things for sale
first off, all the stuff you need to swap in bigger datsun struts. this includes:
late ute/stanza control arms
near new stanza balljoints
stanza steering arms
late ute castor rods
late ute outer tierod ends with new boots and no unwanted play in them
late ute tierods
this is everything you need to bolt later datsun struts (ie sunny, stanza, 180b, 200b 240k, 280zx, r31 etc) into a 1200
only thing that is needed would be new castor rod buches as the ones on these are kinda dead
wanting $150 for the setup
second, factory coupe tacho thats in perfect working order only taken out of my car as i got an autometer tacho very cheap
after around $70
lastly i have a 240k 7/8th brake master cylinder, only just taken out of my car as i upgraded to an R33 master cylinder to suit my brakes a bit better. bought this master cylinder brand new less than a year ago and it works perfectly
is a bolt in replacement for the stock brake master cylinder, just need to make up a new pushrod for it
also goes straight onto 120y, 180b and sunny brake boosters
good for when running 4 piston front calipers, felt good with the r32 4 piston front and twin piston rears on my car
after around $70 for it, only bad thing about it is that one of the reservoir caps is slightly deformed, sat a light near it that was clearly to hot. doesnt have any holes in it and still seals fine....just looks slightly odd
pictures
Posted on: 2008/9/2 12:05
