Re: E15 pulsar dizzy swap
From East Corrimal
Yea you just pull your gear off the current dizzy then you put the gear onto the other dizy then drill the shaft then put the c pin back into the hole.
Get the coil with the Dizzy
You have to modify the bottom adjustment plate and cut a tab off the dizzy housing.
There are two wires forget which colour goes wherer will look 2nite.
The resistor you throw out as well if the E15 dizzy is electric i used a E12 Pulsar dizzy.
Posted on: 2008/9/16 8:16
downie_2579@hotmail.com
grab the coil if you can, the 3 wires are easy, brown green and black i think from memory (not near car atm).
search the wiki
Posted on: 2008/9/16 6:12
From Perth WA
I want to do the E15 pulsar onto A14 dizzy swap, have heard its pretty simple.
just had a look at wreckers, and they all have no drive gear, just a slot. Im guessing u need to put the drive gear from the A's distributor onto it.
Is this easy?
what about wiring can only see 2 or 3 wires coming off it?
what about the coil, do u keep the old one?
cheers john.
Posted on: 2008/9/16 6:09
