(1) 2 3 »
Re: my B110 brake
From Malaysia
Now i gotta see those setups
Posted on: 2008/9/30 19:32
Re: my B110 brake
Quite a regular
From Kedah, Malaysia.
problem solved.... i think my problem was related to masterpump. i had change my masterpump using U12 15/16 unit with B310 servo.. service n change seals to my both calipers... bleeding all round and my problem dissappear... thanks guys 4 ur advice...
Posted on: 2008/9/28 12:50
Re: my B110 brake
From Geelong, Vic
check valve shouldnt cause it, ive ran my car with 4 wheel discs on a disc/drum master for ages without a drama
Posted on: 2008/9/23 14:23
Re: my B110 brake
Quite a regular
thanks guys...
Posted on: 2008/9/23 14:12
Re: my B110 brake
From Townsville, Qld
yours is a disk front to start with right? there's that lil' spring loaded valve you're supposed to partially dismantle when switching to disks, could that be it?
Posted on: 2008/9/23 14:11
Re: my B110 brake
From Brisvegas, oz
the thing that got me with mine was when i changed the system back it was fine again
Posted on: 2008/9/23 11:41
www.camerasplus.com.au
Re: my B110 brake
From Geelong, Vic
if it didnt have enough free play the pedal would pump up till it was rock hard and stay that way, as it wouldnt be releasing the pressure
have you bled the master cylinder first?
sometimes you need to bleed it first to make sure its actually pumping fluid
or just pull the brake lines off the master cylinder and then pump the brakes, obviously have something to catch the fluid, that way you will be able to figure out if the master cylinder is the problem
Posted on: 2008/9/23 11:11
Re: my B110 brake
From hastings,vic
un bolt your master but not all the way,then try and bleed?. sounds like your master is not returning all the way.just leave it loose and try. is the fluid going down when u push the pedel?
TOMMO
Posted on: 2008/9/23 11:02
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Re: my B110 brake
Quite a regular
thanks guys... yes my bleed nipple is on top... hhmmm i think my mastercylinder is the problem. i'll try to change it this weekend. hope will solve the prob. cant wait to try the S13 brake setup..
Posted on: 2008/9/23 10:36
Re: my B110 brake
From Christchurch NZ
I'd say check that the bleed nipples are at the top. You'll never get the air out if they're not.
Posted on: 2008/9/23 10:15
Forced Induction!
(1) 2 3 »
