Re: Wanted Bluebird disc backing plates
From Geelong, Vic
yeah larger disc, r31 is 260mm and bluebird is 280mm
no way they fit in 13s unlike r31 disc
Posted on: 2008/10/14 14:16
From Adelaide, Australia
Really? How come?
My wheels will probably miss the discs altogether, -20mm 13x7s with 50mm bolt-ons.
Oh is it because of the larger diam disc?
Posted on: 2008/10/14 13:37
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Geelong, Vic
need to run the bluebird disc with the bluebird backing plates, makes fitting wheels harder with 280mm discs
Posted on: 2008/10/14 13:31
Yeah the Bluebird calipers bolted onto the car I got the discs from.
I might have a pair of backing plates lined up now, I just need to find a replacement pair.
Cheers!
Posted on: 2008/10/14 13:24
IPRA Build
From Geelong, Vic
bearing retainer is easy, 2 half moon sorta doovers welded in the middle of the caliper mount....would give you pics but dont think i took any when i made boofs ones
r31 discs, bluebird calipers and r31 caliper brackets should still all go together
pretty sure the caliper bracket on the caliper was the same offset between the r31 and bluebird
Posted on: 2008/10/14 13:09
I have 3 sets of R31 plates, 2 just got zinc coated only to find they don't fit straight on, not sure if I want to redrill yet as I need to make some sort of bearing retainer that way.
Been through your photos and saw where I went wrong with parts, I have R31 discs which are same offset as bluebird and some bluebird calipers.
Posted on: 2008/10/14 12:42
IPRA Build
From Geelong, Vic
dont you have a heap of these already....making an army of alloy backing plates are you?
Posted on: 2008/10/14 12:39
bump anyone? even if you have a bluey wrecking, I can drop axles back after removing backing plate.
Posted on: 2008/10/14 7:04
IPRA Build
Will pay for postage, wreckers trying to charge me $120 for 2 axles with backing plates and I only want backing plates.
Posted on: 2008/10/13 12:18
IPRA Build
