Let me understand. You have enough inteligence to install the electronic ignition system either as a kit or a replacement distributor, & also enough smarts & money to buy & fit a replacement starter, but fall short when it comes to buying or borrowing a workshop manual & a timing light.
Simply put, at engine idle, your timing is way over advanced in my view & it needs to be reset to a much more satisfactory position.
I fitted a Pertronix conversion to my distributor without moving it, but discovered that the dwell went from 55degrees to about 40 straight up.
I got the engine started & also discovered, with the aid of a timing light, that the timing was out to blazes. I didn't need the manual to tell me the correct timing as I have done it many times before, [I have several anyway], but I did need the timing light as well as a tachometer to correctly set the timing [+ an extra 2 degrees]
I suggest that you see if you can get a timing light, & someone who knows how to use it to adjust the timing & get a 'best performance overall' figure, then not only mark it on the engine, but write it in a book that you keep with the car for future reference.
ROConnor wrote:
yeah no need for vacume advance with sidedoughts.
Vacuum advance is desirable in any car that sees light throttle settings at cruise RPM, however, because the engine is so overcarbureted [compared to stock] it will in all likelyhood not develop sufficient vacuum to pull in the advance anyway.
This is fortunate since none of the sudedraught carbs of the Weber type seem to have provision for ported vacuum anyway.
If you have a proper vacuum port on the carbs for vacuum advance, then use it, if there is no such port, then simply fit a cap over the little fitting on the vacuum canister.
