Re: Weber MCHH carbs, anyone tried them yet??
Also check out these monsters!!!
2 and 1/2 inch beasts modified from 2 inches!
Anyone say high flow?
The twin fuel bowls are for methanol as its consumed at twice the speed or more in drag racing.
Posted on: 2008/10/29 4:47
From Las Vegas USA
Thanks D that is a definite option............a pal owns an E type and I believe he upgraded to Webers so he likely has a set.
Tom
Posted on: 2008/10/28 1:42
Tom you could pick up jag sus for next to nothing, get them rebuild for 100-120 each inc. slight machining for extra flow on entry area, extrude hone a twin sus manifold, match port your heads to it and simple tuning would cost under $450usd. It will look original and should get you 100hp. There are no jets to play with they adjust from the base and the 2 needles can be changed cheaply.
2 inches is almost 50.1mm each for us aussies.
Posted on: 2008/10/26 1:38
From Las Vegas USA
A pair of MCHH carbs will set me back about $500 for new. I thought about the motorcycle carbs but most of the vintage groups, don't allow them.
Benny you were thinking exactly what I was, tons of weber tuning buts available. A pair of DCOE's would be better but that would involve a new brake pedal set up plus the cost of the manifold and carb................easily $1000-1500 all said and done. I'm only looking to get the motor up to about 100hp, my current thinking is 100HP or 300HP...........why bother with anything in between, if your gonna spend more then 500-600 bucks go all out. ( it's flawed I know)
Tom
Posted on: 2008/10/24 2:53
you have to play with all the jets and stuff very tedious tuning to get right, I suggest for halve the price go for high flowed Jaguar or Rover 2inch SUS fully recoed for way less and get your inlet manifold extrude honed and match port to your inlets.
Posted on: 2008/10/23 5:31
From Sydney
I would say, go for it Tom. If they are indeed based on DCOE design, but single throat, they would be very tunable and would give the little GX a bit more puch
Posted on: 2008/10/23 3:59
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From The garage, NZ
motorbike carbs would work
Posted on: 2008/10/23 3:15
From Melbourne vic
this is them? clickme
Posted on: 2008/10/23 2:21
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
From Las Vegas USA
Some of you may have noticed the weber MCHH carb kits for Triumph and BMC cars as replacements for SU's. They are basically a DCOE spit in half, for those of us with LHD the master cylinders are in the way if you plan to fit webers. As these don't require a new manifold for my GX engine I was considering it. Thoughts???
Tom
Posted on: 2008/10/23 2:06
