Re: front suspension make up? what parts to use?
From Geelong, Vic
yes stanza and 200b struts are basically the same but 200b have inserts that are about an inch shorter....but for a lowered 1200 240z inserts are ideal as 200b stuff is still a bit borderline
either all late ute lower arms and balljoints and stuff with stanza steering arms or make up the stuff as a mix of stanza sunny and late ute stuff
stanza/sunny/late ute/late 120y control arms
stanza/sunny/late ute/late 120y outertierod ends
stanza/sunny/late ute/late 120y tierods
stanza/sunny steering arms and balljoints
late ute/late 120y radious rods
r31 struts will bolt to the same steering arm but will need smaller spring perches or coilover2 and 1200 strut tops
also need to get a sheer load spacer ring so that the bottom of the strut is correctly sitting on the steering arm
Posted on: 2008/10/23 12:56
From Tamworth , NSW
i have 200b struts in my ute.
they were cut 66mm i think, also need to remove spring perches and replace them with the smaller diameter 1200 ones.
for the rest i used all late model ute lca's and tie rods and so forth.
Posted on: 2008/10/23 11:21
From bathurst nsw
hi guys im going to build a suspension upgrade for the new coupe.
from what ive gathered, 200b struts are the same as stanza, but you dont need to cut them down? is this true?
next, do i use the stanza radius rods and tierods with the longer lower control arms and stanza or 200b struts.
and lastly, whats involved with fitting r31 struts if they have been cut down already? eg what parts to use also
cheers kurt
Posted on: 2008/10/23 11:10
My car gets me from A to B...Just faster ;)
