Re: wat tyre profile?
Depends on how accurate your speedo was to start with.
Yes, 185/60-13 or 175/70-13 are about the same height as stock 12" tires, so that should work. Discussion: Tire Size
Posted on: 2008/11/28 18:00
will really depend on what width you want to run.
i found 185/60/13's a close enough match.
Posted on: 2008/11/28 10:31
wat tyre profile?
From adelaide hills
wat tyre profile should be used with 13in wheels to get correct speedo readings
Cheers
Posted on: 2008/11/28 9:45
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
