Re: R31skyline/pintara diff?
From Nyngan, nsw Australia
dattodude wrote: I've had an R31 silouette 3.9 LSD for 2 years that I need to put in. That's the next project, but it will hopefully also include a Ford Falcon watts linkage for the rear end.
id like a LSD center, il just put up with one wheel spin for now....lol,
the watts link be interesting to see
Posted on: 2008/12/13 3:39
living is good,.....
From Sydney, Australia
The R31 Pintara may be 4 cylinder, but 3 litre RB30E powered Holden Commodores used the same diff with Higher ratios (lower numbers).
I run a cut down VL commodore LE Wagon diff in my 1200. 3.45:1 ratio. Open diff with 25 splines. I've had an R31 silouette 3.9 LSD for 2 years that I need to put in. That's the next project, but it will hopefully also include a Ford Falcon watts linkage for the rear end.
Posted on: 2008/12/12 12:17
From perth
once you cut off the ends and suspension brackets a diff (same spline) is just a piece of pipe. weld on the ends for the axles you have
r31 ford commo all the same
with the r31 you get 4 stud (datto) axles and some brakes
the diff is a borg warner 78 series. ford from early 70's, commo from VK? on
Posted on: 2008/12/12 11:50
PIGDOG wrote:
pintara is 25 spline with 4.11 gears
skyline is 28 spline with 3.9 gears in autos and 3.7s in manuals
housings and brakes are exactly the same
my diff is a VN housing, once cut down its exactly the same as r31, with r31 centre and 3.7 gears
so LSDs from holden and ford diffs can be used as long as they had the right splines
cheers champ for the info there thats good to no......
so what ford/holden models has the LSD center for the R31 that i can use?........
Posted on: 2008/12/12 11:31
From Geelong, Vic
all 28 spline centres, open and LSD, that came with 3.08-4.11 gears are exactly the same
so LSDs from holden and ford diffs can be used as long as they had the right splines and gears
ford 28 spline LSDs are the tricky ones here as they came with 2.7 and 2.9 final drive and can only be used with those gears. they might be good for the internals though if you have a commodore or falcon LSD carrier that didnt have 2.7s or 2.9s
Posted on: 2008/12/12 4:28
short-coupe wrote:
yepp they are interchangable housings etc, skyline i thought come out with 3.7's as well. my diff is made up from a pintara housing, r31 axles, 4.11 from the pintara and VN V8 lsd hemi.
a bit of a mix combo there i never new that you could use other center like VN V8, good to no
Posted on: 2008/12/11 20:00
From Brisbane
Posted on: 2008/12/11 11:23
Reson i was asking is i could have got my hands on a pitara diff and i was making sure if i can use it, as i snaped my axle,
all good fella's pickup r31 diff today back on the road again.....
Posted on: 2008/12/11 9:48
From melbourne
yer pintara are 25 spline with 4.11s and the skyline are bigger axle with 28 spline with 3.9s heaps better and maddat make them for datsun 1200 bolt up for around $2500
Posted on: 2008/12/11 7:02
From Armidale N.S.W
Pintara are a poor skyline CA20 4 cylinder therefore cheaper and weaker everything. Some still have discs on the rear that will fit ute diff with slight mods, Just found that out off PIGDOG the walking talking mods and datsun encyclopedia.
Posted on: 2008/12/11 5:35
73 1200 wagon SOLD
