Re: Ca18det turbo headgasket blown
pretty much everything...
ca18det
auto box :(
wiring harness
all pipes etc
Posted on: 2008/12/17 12:40
From perth
may still be a good deal at the right price
ECU harness afm ign module ... etc etc
brakes?
booster m/cyl?
cables hoses ducts...
Posted on: 2008/12/17 11:27
From Albany, Perth Australia
what! a ca with a blown head gasket, never! hahaha i like the plug you put in dazza. always good to find out whats wrong with the head before buying, you never know what its like
Posted on: 2008/12/17 11:00
1200 Smerf Mobile
From perth
ca 's have a graphite gasket from factory
they last about 10 years
you do the math (1989)
if you get one thats not blown its about to
so if you can get it cheap its a good deal
if its brown in the water passages its been blown a long time and head may be corroded (there is no way to tell until its off .can you purchase subject to disassemble and check?)
you WILL have the head faced while its off
deck surface can corrode too
dazza, ca 1200 owner
cyl head machinist
southside engine centre ,myaree
93171233
Posted on: 2008/12/17 10:52
From Sydney, Australia
Headgaskets blow for many reasons. Mostly they blow from overheating.
On an OHC it's a bit harder than the old A12.
But it's sure not impossible if you are competant with replacing a CA18 timing belt.
You might want to get the head skimmed while it is out to ensure it's flat.
Posted on: 2008/12/17 10:40
whats a ca18det engine worth with a blown head gasket basically a front cut...
how hard 2 do the headgasket? and obviously would of blown because of too much boost???
Posted on: 2008/12/17 7:24
