Re: Well I guess I did it.
irrelevant. This car only goes forward, no need to turn right or left
Dman, thanks for that info. It never occurred to me that the ute rear axle and Datsun Competition axle housing is straight from the PB110. It makes sense.
Posted on: 2009/1/6 3:14
From ACT Aus
just try not to get a monster huge diff that is way to heavy for a small car. my car has a torana diff in it which would weigh about 90kg's and you can feel it just pushing the car around and making it understeer.
Posted on: 2009/1/6 0:20
From Snohomish, WA USA
Well, broke the left axle shaft inside the bearings on the pumkin. I guess that's the reason why it never broke loose and rattle inside my rear diff. Replace the bearing and axle and it's fixed but I'm not going to go that route. Think I'll pick up something a bit beefy'r.
Are H150, H165 or H190 the same width, drum to drum? How about the drive shaft bolt up pattern?
I want to make the swap over as simple as possible.
Thanks.
Posted on: 2009/1/6 0:00
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Christchurch NZ
May have to bite the bullet and have a 720 diff shortened up for it. in the long run a properly strong diff is the only way to go. Shagging about changing heads is only shifting deck chairs on the titanic when you have lots of grunt and a heavy foot.
Posted on: 2009/1/5 20:22
Forced Induction!
The P411 used an alloy carrier version of the H165 in the 'rear' diff [to distinguish if from any other diff a 1200 might have]
These will bolt into the 1200 Ute rear axle housing [which is not readily available in Washington state] They will also bolt into the PB110 & PB210 Excellent rear axle housing [from which the ute rear end seems to have been derived] Unfortunately there are not readily available in the US either.
These earlier diffs use a different spline in the side gears & are a 4.11 to 1 ratio.
Simply put, the early [alloy carrier] H165 differential will not fit either the H145 or H150 axle housing & even if you had the correct housing to use it in, the 1200 axles will not plug in.
It may be possible to rebuild it with the later side gears from the [iron carrier] H165B but you will still need a suitable axle housing for it.
I also think it will not serve you too or too long well if you continue to dish out the level of abuse that you describe.
Posted on: 2009/1/5 10:38
Love your Datsun.
Treat it well.
From Geelong, Vic
thought 411s had h165s with small axles
Posted on: 2009/1/5 8:39
From Wagga Wagga, NSW
Sounds like a little ball tearer.
+2 for dyno
Posted on: 2009/1/5 8:24
I think the 411 came with H190 diff. Should be plenty strong.
Posted on: 2009/1/5 6:18
Going to pull the diff apart tomorrow but got a lead on a new diff. There is a lady here in Seattle that I have know for years that deals with vintage Datsuns. Pre 1200 stuff. Never had a need for any parts from her but she's got some rear diff's out of some 411's.
I believe these are H165's, I think.
We'll see tomorrow what my H150 looks like.
Posted on: 2009/1/5 6:00
'73 2 Door Sedan
You should put this thing on a dyno once you've got your rear axle woes sorted. I'd love to know how much power it makes.
Posted on: 2009/1/3 22:21
Forced Induction!
