Re: Electric fuel Pump! What is needed!
No electricity needed.
Dual carbs use the same: about 3 pounds of fuel pressure.
Posted on: 2009/1/24 6:27
From Melbourne vic
electricity?
Posted on: 2009/1/24 2:16
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
From Charlevoix, MI USA
Most aftermarket electrical fuels pumps will come with everything you need for install. i.e. wire, mounting bracket, some even come with a fuel filter, and additional directions for wiring it into your oil pressure switch for emergency shutoff.
Assuming you are running a stock Hitachi carb or Webber 32/36, you should not require a pump that puts out more than 4psi. 3 to 3.5psi is probably ideal.
You might need:
1. Additional wire
2. Additional lengths of flexible fuel line
3. In-line fuel regulator
4. A new grounding location
You will obviously need to get or fabricate a plate to cover the hole left from the mech fuel pump.
If you are running some type of dual carb setup or fuel injection; I will leave that to someone else.
Posted on: 2009/1/23 18:52
"from the land of the graceless bumper"
'78 B210GX BREwannabe'
From Lisboa-Portugal
If we replace the mechanic fuel pump for an electric one what do we need beside the electric fuel pump? Sorry for the stupid question!!
Posted on: 2009/1/23 18:02
