Re: help me! i hate panel beating
From Perth WA
if u can, post up pics of these dents from the outside and what u can get to inside,
u dont want to stretch the steel and need shrinking, an easy enuf trap to fall into. We can give u more of a guide then. Rubber or wooden mallet to bump it out is a good start to avoid stretching.
Posted on: 2009/2/10 8:29
From Croydon Victoria Australia
A12 GX.
DOOOOO IIIIIIIIIT!!!!!!!!!!!!!!!!!
Posted on: 2009/2/10 8:16
'84 ute, A14 on LPG
'72 Sedan Auto parts car
___________________________________________
"Something's rotten in the state of Pistolero"
From Darwin NT
datsandy
in another 10-20 yrs how many real good panelbeaters do you think will be around? sure still there a few good ones around but with most of these new cars its either replace panels and do a bit of straightning, bit of bog here and there and your done or its completly ####ed and the insurance company writes it off OR the panelshop doesnt want to know about it so do you think all the aprentice beaters are going to learn how to cut and shut rust and restore a 40 year old car that is pretty much ####ed?
and im sure its not like it would have been 20-30 yrs ago where it would have been cheaper to repair the panel then replace it
and you being a man in the trade for as long as you have stated would probably understand this?
and id rather have the joy of knowing that there is less bog in it due to the fact that i took it to the beaters to do the bits i couldnt
Posted on: 2009/2/10 8:12
current project 4x4 patrol...
From Tamworth , NSW
it is your car to do what you will.
but pleeeeease for the love of god put the rotor in something else!!!! these 2 doors are just too rare here.
From Adelaide, Australia
ur all going to hate this but i recon im going to go a rotor. it can be put in without cutting anything and i can put a 12a in it so a nice 12A large extend will be good. A series are good but its too expensive for a box. plus i have a rotor bug again
Posted on: 2009/2/10 8:09
From Far, far away
Keep plugging away, it is hard but at least it will be done to your liking. Panelbeaters tend to take their time with this kind of work as it doesn't make them much profit.
As for the motor I'd love to hear of your plans. If it was mine I'd be hunting down a A12GX. CA or SR would butcher such a rare car, keep it as close to original as possible.
Posted on: 2009/2/10 8:01
Matto1kute it all takes patience. You should post some pics under project builds so we can
1. Be jealous you have a 2 door sedan and
2. Track your progress and give you feedback to help keep you motivated.
Now is a crucial time to not take shortcuts and persevere, even if it means doing repairs twice.
Shortcuts and lack of patience now will be evident in the finished product.
Also, be sure to check out Datsunbat's car in project builds
Posted on: 2009/2/10 7:50
'84 ute, A14 on LPG
What about the engine? What are your plans?
So has she been rubbed down ready for first coat? I went down to 600 grit on my 2 door in PNG, you need to get that base nice and smooth with no imperfections.
Posted on: 2009/2/10 7:41
From Armidale N.S.W
What a crock of S@#t datto1000wagon There are still plenty of good panel beaters around but my point would be your taking away the joy of knowing you did it yourself. Hang in there mate when ya feel its pretty close hit it with primer and a couple of coats of Spray putty then guide coat it then dry block it with 120 quick scuff with 180 couple more coats of primer filler guide coat again and youll be sweet. Sounds simple maybe but i guess near 20 years of doin body work helps. If ya want some help or get stuck PM Me i'll give ya me number and talk ya through a few things ive learned which you may or may not know..
73 1200 wagon SOLD
all front panels are in primer aswell as the roof,boot, engine bay and inside of where the doors go. the doors are nearly done. just the seals and 1/4's
Posted on: 2009/2/10 7:35
