Re: Need to know !!!!!!!!!!!!
Quite a regular
From Orange County, CA
Yes, the 120y crossmember will fit in the 1200 coupe, but the bolt spacing is different, so you will have to move the 120y xmember forward 1 bolt hole and then drill hole in the 1200 frame
where the other bolt hole in the 120y xmember is supposed to be. The 120y steering linkage will bolt right in place. Of course, you will have to use the 120y struts if you want to use the
120y linkage. I had to do all this to my 1200 anyway, because it was almost a shell when I got it, and I couldnt find a 1200 engine and tranny, so I thought, What the heck, why not just swap
the front suspension , engine, tranny , diff, etc from a 120y?My 1200 is coming along great. The only thing not stock in my 1200 is all the above mentioned modifications, but it would be hard
to tell unless u opened the hood for a look-see. Of course , like MareoSpeedWagon is fond of saying, you can do this if you're mechanically inclined.
SMJ
Posted on: 2001/8/9 8:47
Will a 120y front cross member (the part the engine bolts on to , not the gear box) & steering fit into
a 1200 coup.
Posted on: 2001/8/9 6:47
