Re: where to get CA valve stem seals
From Geelong, Vic
only gotta find turbo lines now...then it will finally be together
Posted on: 2009/3/18 3:35
so it looks like the easter bunny is bringing the cade turbo conversion to a car near you ????
Posted on: 2009/3/17 20:43
From perth
ndk is a typo
nok is a japanese seal company that supplies most oem stuff
Posted on: 2009/3/17 10:54
From Geelong, Vic
so who wants to hear a joke???
ordered some CA valve stem seals from the local bursons using that permaseal part number
went in today to pick them up and my mate behind the counter said the price would be $120....and that they had a list price of $180. for 16 valve stem seals...non genuine valve stem seals
he was even thinking they should be around $50, so check the part umber numerous time with the same result
then figured for that price a vrs kit might be the better option, list price on that is $250
so thought id be best to just leave bursons and try else where.
went to the guy thats doing the heat, told him what was going on, he also thought that was damn expensive for valve stem seals so he made some calls
first place he called obviously quoted the same price as bursons as his responce to them was "oh they are that bad are they"
so called another place that had a listing for CA18de....$40 plus gst WINNER
Posted on: 2009/3/17 10:44
From Geelong, Vic
yeah already got a genuine headgasket, cam seals. inlet and exhaust gaskets so dont really want to go buying a VRS kit just for the stem seals
might just talk to my mate thats doing the head and see if he can get some, but think he said he could only get the vrs kit
still no luck with oil lines, second person to say they had them....second person to just decide to not respond fter a couple of pms
some ppl just deserve a punch in the mouth for wasting my time
Posted on: 2009/3/15 10:44
From Sydney, Australia
Intake valve oil seal Jan 1991 - Dec 1998 13207-84A00 NDK
Intake valve oil seal Jan 1991 - Dec 1998 13207-D4201 NOK
I don't know what NDK or NOK means..but both numbers are in the Nissan FAST parts catalog under CA18det S13.
I'd refer to the 13207-D4201 if I was taking a guess.
The RB25det uses the same seals 13207-D4201
Posted on: 2009/3/14 4:12
From perth
should be around $4 ea aftermaket payen/permaseal/durapro try precision,veales coventrys or similar
did you find some oil/water lines?
dazza
Posted on: 2009/3/14 3:20
From Melbourne ( West )
I Just had mine done at Hoppers Crossing Cylinder Heads.
They do a fair bit of Nissan stuff including CA's
I did supply mine because I got them in the gasket kit,
but I was after a set of head bolt washers (over a month wait from Nissan and $7.80 each x 10)
I Rang Hoppers Heads and they said 'Too easy... come and grab em' (free)!
Long story short - I'm sure they could help you out.
Otherwise:
Ajusa Part No. 336-RV (Valve stem seal set)
Posted on: 2009/3/13 7:23
'78 Ute CA18det Project
No matter where you go... There you are
From gold coast QLD.
I got them with my last non genuine VRS set.
CA that is
Posted on: 2009/3/13 5:56
From SE Melbourne
does anyone remember if they are part of a full VRS kit? I know they were for the A series....and have a feeling they were for CA too.
Check this out - AA Gaskets/Permaseal P/Ns
http://www.aagaskets.com/EngineDetails.aspx?EngineID=1152
Posted on: 2009/3/13 5:21
Mildman, Datsunless
