Re: Connect Oil Presure Indicator Bulb
From Charlevoix, MI USA
Can't seem to edit my post:Should read,
If your eastern hemisphere model has an ignition relay, I can provide you with that info.
Posted on: 2009/4/9 0:32
"from the land of the graceless bumper"
'78 B210GX BREwannabe'
If your eastern hemisphere model ignition relay, I can provide you with that info.
pdf Oil Pressure Warning Light 1978 Datsun B210 GX (USA).pdf Size: 251.35 KB; Hits: 152
Posted on: 2009/4/9 0:27
From Mandurah, Western Australia
One side of the bulb/lamp is 12 volt positive. The other side has the wire going to the engine which is earth. The senson on the engine increases in resistance as it gets hot which completes the connection to earth and turns the lamp on.
Posted on: 2009/4/8 11:24
From Sri Lanka
Hi Guys
How Oil Pressure bulb at dash board would be enabled , what are connection to oil sensor it it Ground earth or voltage(means do i need to supply electric to sensor or only to dash board light) ?
Thanks
Regards
Sumith
Posted on: 2009/4/8 6:31
