Re: 120y coupe going too fast
Yes, no 120Y has ever gone too fast.
Here's my 1200 speedometer:
Reads: 35
Actual: 29
Posted on: 2009/4/12 20:55
From Townsville, Qld
Man a 120y can never go too fast :P....
Posted on: 2009/4/12 9:59
From northern 'burbs adelaide
the original calibration would have been for 12" cross ply tyres which are bigger in diameter then the modern 12" radials ... a set of 13's with like 70 profile tyres will fix it all up
Posted on: 2009/4/11 15:17
From Brisbane, Australia
Thanks mate, I was thinking it would be something like that.
Posted on: 2009/4/11 4:54
The gearbox probably was originally in a 13" tyre vehicle.
You just need to get a different gear for the end of the speedo cable thing that goes into the gearbox.
Posted on: 2009/4/11 3:25
The needle is smooth in motion, just doestn't read correctly. Is about 20km/h out gets further out the faster you go.
Posted on: 2009/4/11 1:32
From Toowoomba, Qld
does the needle move smoothly from slow all the way to fast or does it 'flick' around?
if it flicks a bit it's likely the cable. If it's smooth, its likely the guage.
Posted on: 2009/4/10 23:37
Stock 12 inch standard profile tyres.
Thanks
Posted on: 2009/4/10 23:30
From Toowoomba, Qld
What size rims and what profile tyres are you running.
That can also have an effect on speedo reading.
Posted on: 2009/4/10 23:18
Hi, was wondering if anyone had any ideas as to why my 120y coupe is reading slower than what I'm actually going. It reads 80km/h when the gps tells me I'm doing about 100 km/h. Was thinking it could maybe be a seepdo cable issue. It has a A14 with 56a 4speed in it.
Thanks Geoff.
Posted on: 2009/4/10 22:56
