Re: 1200/120y struts and coilovers
They are 2" (50.8 mm).
Most Datsun struts are 2".
Datsun 1200 and Aussie B210 are 45mm.
JDM B210 and USA B210 are 2".
Posted on: 2009/4/15 2:50
From australia tasmania
okay, so stanza/200b struts ARE 51mm....?
can get good shocks and sleeves for that size.
it would make sense to do a brake upgrade at the same time as putting awesome susy in.. :D
thanks
Aaron
Posted on: 2009/4/15 2:44
old skool cool...
www.shakotangarage.com
From Townsville, Qld
aid ur smoking crack
It's alright bud it must be an Aidan thing cos I get that all the time too :P
Ps: 120y struts are 45mm od
Posted on: 2009/4/14 9:37
From Adelaide
nope all 120y are 45od
Posted on: 2009/4/14 9:10
maybe dpends on what type of 120y ones, there seem to be jap and aus types, maybe one is 45 and other 51, or maybe he just has different struts already
Posted on: 2009/4/14 9:07
From Adelaide
120y are only 45 OD lol
aid ur smoking crack when u measure
Posted on: 2009/4/14 9:04
hhmm,
thanks for the info guys.
ill be putting up a add in the FS section soon. depending on how much interest may keep a pair of struts in stock and do an exchange system with out other coilovers. could also convert your own struts to coilover and send them back to you..
thanks
Aaron
Posted on: 2009/4/14 5:38
old skool cool...
id be up for a set for my 200b struts or stanza
ta nick
Posted on: 2009/4/12 14:24
Car free
From northern 'burbs adelaide
120y struts are 51mm OD ... just did a set on my ute and if i had extra cash i would have put coilovers on it as a 51mm kit is avaliable
Posted on: 2009/4/11 15:14
From cranbourne, vic
45mm od, i cant remember exactly but i think its 640mm over all with a 416mm body. i just put them in my drum struts to get me by untill i go disc, so i cant be sure.
im going to use 81 pulsar shocks (monroe pn:25-3436) ,over all - 551mm and body lenth 334mm with 10mm less travel and same 37od body.. im using 51mm coil over sleeves, with a sleeve over the 120y made from 40nb 2.5mm wall tube (you need to cut it length ways and open it up then slide it over) and then welded that to the strut. i cut the strut down too 360mm from the top to the bottom where it bolts to the steering arm.
Posted on: 2009/4/11 9:44
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
