Re: welding
ps got some 3mm steel and even 6 mm for over kill if needed, i still can find these ferrals you talk aboutm, just crush tube, same thing i guess, do i have to weld that in too or just make it nice and tight fit?
Posted on: 2009/5/16 1:46
Re: welding
no i use caststol gtx 2 for that, and used oil for that black, slick cour and apprearance.... its noce to at least have hair currently in winter.... hows the chrome up top there don ;)
Posted on: 2009/5/16 1:44
Re: welding
Use bolts. It's the best and safest way. When you bolt to the chassis and you have a hollow area you need to use ferals (steel tube) so that you don't crush the rails. And big washers. Or beter, squares of 3mm steel for washers. I thought that you were going to mention that you use the fish oil in your hair...
Posted on: 2009/5/16 1:37
Re: welding
i love fish oil... its great, especially if you spray it on with grease smeared on top of it, stops a lot of rust.
Posted on: 2009/5/16 1:23
Re: welding
do it the right way bolt through chassis and spray
some fish oil inside the rails while you are at it.
Posted on: 2009/5/15 13:15
Re: welding
From Ipswich, QLD
if you use a 1.5mm rod you should be reasonably okay welding 3mm to 3mm but anything thinner than that and you going to get a lot of holes.
Posted on: 2009/5/15 7:17
Re: welding
From Perth WA
the holes are where to bolt on not weld up. U need to go into the rails either right through the boot floor or from underneath, u cant just weld plate onto the boot floor to take towing.
Posted on: 2009/5/15 3:54
Re: welding
tow bar has 4 mounting points. 2 wher bumper mounts up and 2 trough rear chasis rails underneath, theres even piolet holes in the chasis rails for them
Posted on: 2009/5/15 1:46
Re: welding
From Wagga Wagga, NSW
Generally avoid trying to weld any thin "precious ;)" metals with an arc welder, mig or oxy on the other hand... go for it
Posted on: 2009/5/15 0:26
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
Re: welding
From Darwin NT
dont weld just have the tow bar bolt to where the bumper bar bolts up to on the chassis
Posted on: 2009/5/15 0:16
current project 4x4 patrol...
