Re: 1200 ute, fuel tank question.
non-EVAPO tanks have a vent hose on the top of the tank. The hose goes up into the body and loops back down to the ground. It is just for venting.
Aussies, how are your ute tanks vented?
Posted on: 2009/5/27 7:25
Not too shy to talk
From Guatemala
thanks again.. i've checked and it does not has any vent on the engine compartment i'll try to put the fuel tank off to check every little detail on it.
Posted on: 2009/5/27 5:56
Datsun Project.
Newer 1200 pickups (1978?) use EVAPO instead of a hose loop.
1200 Pickup Fuel Tank
The actual vent is up in the engine compartment, looks like this:
Flow Guide Valve
Posted on: 2009/5/22 6:16
Not too shy to talk
From Guatemala
whoa.. nice info.. that's exactly the regular cap i've bought. so, i'll check out the hose loop.
Thanks for the info!!i think my 1200 use the EVAPO system.
Posted on: 2009/5/22 6:02
Do not drill the cap. I will cause a leak.
No 1200 cap is designed to let the vapor out
1200 caps are not vented.
* Early caps are 100% sealed, tank vents via hose loop
* Later caps have vacuum relief. They let air in, but not out. Tank vents via valve in engine compartment.
Regular cap vs. Relief cap
Also see Fuel Tank Venting
Posted on: 2009/5/22 5:11
Not too shy to talk
From Guatemala
thanks for the advise. but, is that right to drill the cap? would this cause to fuel vapor out?
Posted on: 2009/5/22 4:31
Not too shy to talk
From Gold Coast
Hi Samm early model utes had builtin vent in the cap,u need to find the correct cap or do as i did and drill a pin hole in the cap.
Posted on: 2009/5/21 13:45
Not too shy to talk
From Guatemala
Hi guys, my name is Samm, i´ve registered a few time ago but till now i'm frequently visiting the forum.
I know you all can help me with this..
¿Does the fuel tank of 1200 ute has any bypass on it, that lets the air in with suction but won't the fuel vapor out?
The question pops out, cause i bought the original fuel tank cap, suddenly the tank became completly sealed, this caused an engine stop because the fuel pump could not suck any more fuel.
when i released the cap it was liked vacuumed creating suction into the fuel tank, after removing it the car started normally.
So i need to know if it really has any way to let air in but not to let fuel vapors out
thanks for your help guys.. i'm gonna be around here for a long time and introduce my ute too.
Posted on: 2009/5/21 13:04
