Browsing this Thread:
1 Anonymous Users
Re: interchangable wheel hub question |
From cranbourne, vic
just run some slip on wheel spacers if you need short term fix... as long as your studs are long enough, spacers are $25 a pair usauly... dont get the cast ones!!!
120y disc and 1200 disc hubs are the same, sunnys (b310) i believe are have the larger stub axel, so they wont fit. from a glance the 1200 drum hubs and 120y wagon drum hubs look the same but i havnt had them side by side yet..
Posted on: 2009/6/22 9:08
82 1200 ute - daily 89 R31 H.M.A.S. Skyliner - drifter 197? 1200 coupe - new drift project. 85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
Quite a regular
From Canberra
thanks mate but its definately not a nut problem. The thread on the wheel studs doesnt go all the way to the hub. It stops about 5mm from the hub and then has a beveled spline shaft so the nut wont go down far enough to clamp the wheel. Now the mechanic says the studs were oversized so puting the correct ones in doesnt work cause they are loose in the hub. arrrrgggghhhhhh
Posted on: 2009/6/22 8:21
i still think wrong wheel nuts.
Posted on: 2009/6/22 8:08
Quite a regular
From Canberra
Hey am having problums with my 1200 74 ute. Does anyone know if wheel hubs are interchangable between 1200, 120Y and Sunnys. The front wheel hubs.
My hubs have had oversized studs pressed into them so now i have to put 13" wheels on the hubs wont keeep the wheels secure. thanks for the advice...........xxxxxxxxxxxxxx..........
Posted on: 2009/6/22 7:43
