Browsing this Thread:
Re: resetting leaves
From cranbourne, vic
if you keep the standed main leaf, your shackles will cope with any height you want..
Posted on: 2009/7/23 8:45
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
From cold toast
haha,
bit of a hookie ay?
Posted on: 2009/7/23 8:43
From gold coast QLD.
Ah Pepper thats priceless!!GOT A TEAR RUNNING DOWN MY CHEEK
Posted on: 2009/7/23 8:40
From Brisvegas, oz
the 3inchs drop doesnt equal 3 inch back, i have mine reset 3- 3.5 inchs and its almost the same as standard
Posted on: 2009/7/23 8:39
www.camerasplus.com.au
From cold toast
awww
okay my mistake
cool (Y)
thanks dudes :)
btw i love your ute, what did you get the flares off?
Posted on: 2009/7/23 8:38
From Tamworth , NSW
no no no no, just because your resetting the spring 3 inches lower doesent mean that the spring will be 3 inches longer. the spring is only getting flatter, which will make it slightly longer, but not a lot at all.
if it made that much difference im gonna get my third leg straightened if it adds 3 inches.
Posted on: 2009/7/23 8:36
From cold toast
yeah i do get it dude
just that if the spring gets lowered 3 inches, then the spring would be 3 longer? then the swing arm would be pushed back 3 inches, thus almost hitting the chassis?
Posted on: 2009/7/23 8:32
From Tamworth , NSW
yes! the spring would be slightly longer, but the hangers at the rear of the spring move to compensate for the changes.
look at the difference between the front spring mount and the rear one, think about how it all will move and it will become clear.
Posted on: 2009/7/23 8:26
From cold toast
yes i understand this,
but if i was to get the springs to be set like 3 inches lower, wouldnt that push the swing arm back much further instead of being straight, this is when the car is standing still
Posted on: 2009/7/23 8:10
To answer both questions:
Yes
Yes
Just as they go back and forth as you are motoring along over bumps.
Posted on: 2009/7/23 8:04
