Re: Branco brothers datto project
From Portugal, Lisbon
The price for One - Datsun a14 single weber Manifold and Linkage kit (K625) his still the same. 189$ + shipping
TS
Posted on: 2009/10/12 11:19
From northern 'burbs adelaide
now now who are you calling a yobbo?
Posted on: 2009/10/3 16:52
Thanks Daniel,
I'm gone ask them the actual price
Posted on: 2009/10/2 16:03
Webmaster
From Lisbon - Portugal
Webmaster
I've got the name from them
daniel
Posted on: 2009/10/1 16:35
Keep them alive and sideways!
From Perth WA
the thread title is a bit worrying coming from portugal,
I thought only aussie yobbos called datsuns dattos haha.
Posted on: 2009/10/1 2:30
datsun 1000, Its not the size its how u use it.
Webmaster
Webmaster
Hi,
Just a progress report, I've finished the light head port and polish and my mechanic went on is own to assemble the bottom... I was hopping to do it my self and learn something, but can complain, it looks good!
Next it's the Weber rebuild and some compression calculations.
Here are some pics:
daniel
jpg  small_IMG_8841.JPG (74.85 KB)
7_4ac3e8eabc7ef.jpg 800X600 px
jpg  small_IMG_8842.JPG (68.98 KB)
7_4ac3e90021535.jpg 800X600 px
jpg  small_IMG_8846.JPG (55.08 KB)
7_4ac3e91379c32.jpg 800X600 px
jpg  small_IMG_8849.JPG (70.37 KB)
7_4ac3e922acbc0.jpg 800X600 px
jpg  small_IMG_8843.JPG (86.53 KB)
7_4ac3e92b31aac.jpg 800X600 px
jpg  small_IMG_8844.JPG (80.53 KB)
7_4ac3e93a46032.jpg 800X600 px
Posted on: 2009/10/1 0:28
Webmaster
Webmaster
Hi,
I've bought it here http://www.topendperformance.com/.
This was the quote from them, I don't know if it still valid.
One - Datsun a14 single weber Manifold and Linkage kit (K625) - $189
Two - Rebuild Kits - $64
Two - Jet Caps - $32
Shipping - $69
Maybe you can get a lower shipping with out the other weber parts.
daniel
Posted on: 2009/8/19 21:17
DanielBlues where did you get that single weber manifold?
I'm starting a project with an A15 for my 1200
Abraço
Tiago Santos
Posted on: 2009/8/19 15:52
32mm chokes should be very good for A14. Go for plan #1 the Weber 40.
Posted on: 2009/8/14 3:50
From sydney australia
That 40DCOE should be fine, I ran an A12 with a single 45DCOE between 1985 & 1987 & it had no problems. Looking at your main jets & air corrections, I think you should reduce the size of both. That's a lot of fuel going through an engine, even if it is in the correct air/fuel ratio. the rest seems fine. That manifold looks a bit short, though you do have a master cylinder in the way. the mainfold I had was the same style, the runners were just a bit longer. it was probably a bit better for low down response. If you could install a little cam it wouldn't hurt. The factory 70 degree cam is what I'd recommend. It's a little warmer than a GX cam, but still makes streetable torque.
PS change the needle & seat to a 2.0,this'll allow more fuel into the carb, never hurts to have more supply than demand.
Posted on: 2009/8/14 1:13
