Browsing this Thread:
1 Anonymous Users
Re: Factory 70 degree cam specs? |
Registered Users Contentmaster Usermaster
fandatstick, can you list the specs for the other cams?
As far as I can find, these cams were not delivered in any roadgoing cars. They are only in the Nismo/Competition catalogs.
Nismo current catalog lists: * 99996-H1031: 310 degrees, 0.487 lift Old Nismo listed * 99996-H1032: 320 degrees, 0.487 lift * 99996-H5741: billet * 13001-H5775: Semi-finished
Japan and North America production models only used one of the four typical grinds, and not any of those cams. I checked B10, B110, B210, B310 and B120 catalogs. The GX cam (13001-H2300) is the strongest of the production cams (most lift, most duration). It is stronger than the A12T/A14T cam (13001-H5700).
Posted on: 2009/8/23 0:29
From NZ
From my tatty photocopy of B310 tuning manual.
70degree Factory Cam specs at 0.010" valve clearance: Duration 280degrees Inlet Opens 38 / Closes 62 Exhaust Opens 65 / Closes 35 Lift at Cam 0.370"
Part no. for the actual factory part was 13001-H5710. 70degree is a fairly mild/fast road cam - 80A (320 duration/0.413" lift) degrees) or 82 degree (328 duration / 0.413" lift) are pretty hairy though! Cheers
Posted on: 2009/8/22 10:27
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box. Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
From sydney australia
The 70 degree cam is a sports option part. It's listed in the Sports Option Parts listing for the B210 dated Oct 1 1977, Ref No R/B-210. The part number it's listed under is 13001-h5710. This part number is probably NLA. I've had a couple of cams of this grind here in Australia because somebody had a copy of the Masters, so they could make copies. It was a strong cam, with a wide power band, I had it mainly in an A12 with a 32dgv weber & it'd drive around like a stock engine, then blast off when you opened the throttle. I can't tell you the specs, but if you email Stewart Wilkins Rallying here in Sydney, the man I used to get them through works there. His name is Arthur Jackson, he might be able to arrange to get a cam ground for you, or at least tell you the specifications so you can get it ground there in Portugal.
Posted on: 2009/8/21 5:24
Factory cams are those produced by Nissan.
248/248 A12 248/244 1981-1982 hi torque 256/256 [edited] A12 GX 256/248 [edited] A14/A15 hi power
Then there are the Nissan Competition cams. Since the Wiki is broken, I can't look them up right now.
Posted on: 2009/8/20 21:35
Edited by ddgonzal on 2009/8/23 0:32:24
Webmaster
From Lisbon - Portugal
Webmaster Registered Users
Hi, I've search but didn't find the specs for the factory 70 degree cam that b310gx refered in my datto project. I've found this list, is it any of this? http://www.camtechcams.com.au/cat/nissanA12.html? thanks daniel
Posted on: 2009/8/20 11:23
Keep them alive and sideways!
