Re: engine mount brackets
From Oberon NSW {Bathurst}
SOME MOTHERS DO AVEM' Let me see if I have it right; Acne, cap on backwards and drives a VL Dunnydoor is my guess!
Posted on: 2009/10/8 14:24
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
From Geelong, Vic
how could you think they are bent though...the mount surface would still be flat with the block mount. and all the bends are nicely pressed smooth bends
tell your mechanic to not give up his other day job
Posted on: 2009/10/8 9:26
1970 model. Standard A 12 engine with no mods at all. From all the fantastic feed back it appears they do go forward so now I can tell my mechanic he doesn't know everything. Thanks heaps.
Posted on: 2009/10/8 7:24
This is the factory 1971-1973 Datsun 1200 (Coupe, ute, sedan, wagon) mounts:
the two bolts are where the crossmember is, motor mounts look about 2" forward, as already stated.
larger pic Left larger pic Right
1974-up are different.
Posted on: 2009/10/8 4:49
From gold coast QLD.
Pigdog is spot on they go forward about 2" from centre line.
You gotta watch some of these so called"mechanics"unless there old school they would'nt know half the time.
Cheers
Posted on: 2009/10/8 4:02
From pooraka,,adelaide
woops my mistake i read it wrong
Posted on: 2009/10/8 3:33
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
From Geelong, Vic
nah the engine mounts on the crossmember are supposed to go forwards a little bit
mount bolts on about 2 inchs forward of the centre line of the crossmember
Posted on: 2009/10/8 3:30
wot year is it? wot engine does it have in it? it may have home modded engine mounts to account for a early -late model engine swap??
pics would help
Posted on: 2009/10/8 3:21
vanette-a15 turb
260c- daily
1000 4dr- a15
garage 910
Just bought a 1200 coupe as I've finished my 1000 coupe. My mechanic says the engine mounts are totally bent. He says they should be straight up from the cross member. At the moment they bend towards the front of the car then straighten and everything engine/radiator wise looks in the right spot. Any help?
Posted on: 2009/10/8 3:18
