Re: a12 wont rev past 5000rpm
What did you do regarding timing and fuel?
To rev to 6000, use stock timing (5 to 7 BTDC) and stock jetting.
Posted on: 2011/6/23 17:31
maybe accelerator cable is stretched like Madonnas ear lobes :))
Posted on: 2011/6/23 9:50
From Near Bundaberg QLD
supafatto wrote:
it was timing and fule
thanks to tommo it now will rev to 5500 thats as far as ive pushed it but it does get to 95mile lol :)
What did you do regarding timing and fuel? What did you change, and what did you change it to? (what settings)
Posted on: 2011/6/23 9:39
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
Yes. Even 40 year old stock valve springs will rev to 6000+.
it's probably the distributor timing ... he may have it retarded.
Posted on: 2011/6/23 6:23
From Los Angeles,CA
I'm not surprised that it won't rev much past 5000... The stock valve springs are soft enough to compress by hand!
Posted on: 2011/6/23 5:46
From MOOROODUC. Victoria
My coupe will rev out to about 8500 but its been balanced and has two 42 mm webers and electronic ignition. and the head has double valve springs and larger inlets.
but even at that i have my fingers crossed
Posted on: 2011/6/21 0:35
From Sydney, Australia
In 1990, My bog stock 200,000mi A12 revved to 6600 in 4th, with standard fuel and carby.
Was valvebouncing..
I used a digital tacho (quite hi-tech for the time).
Posted on: 2011/6/20 13:03
Mine does the same thing! It can't rev past 5k with a 32/36 weber. Hoe do I fix this? I've got a brand new pump laying around at home, new plugs, points and leads. Timings adavanced 8. Stock standard motor other than the weber.
Posted on: 2011/6/20 12:40
MUNCH MUNCH PISTONS FOR LUNCH
Posted on: 2009/10/10 1:14
Car free
Quite a regular
From rockhampton qld
i find that if i actually have a long enough straight line i can get mine to about 6500, i haven't tried for more cause noise and rattles are a little scary, besides that is where the factory says it makes its whole 69hp.
i would guess at a timing or fuel prob too, mine is bog standard and can get it to there.
Posted on: 2009/10/9 15:13
