Re: CA18 coil pack upgrade question????
From Adelaide, SA
thats exactly what i wanted to hear cheers man, ill post somne pics up when i do it
Posted on: 2009/11/14 0:44
From Adelaide
smithy.. doesnt listen to them stories.. all it does is gives better spark.. bigger spark an wont fail.. one bosch can start a EA falcon.
go with the bosch, dont waste 700 on superspark or the other #OOPS# one..
no mods needed u just need to mod the loom which is adding cpl ground wires for each coil
Posted on: 2009/11/12 23:56
From Adelaide, SA
-Ben did you have to make computer changes to get the bosch coils workings cos i getting mixed stories. i have read the nissan silvia thread it seems easy enough to do but people have posted about needed to modify computer to suit. i cant really afford to be changing computer at this stage. the enigne looking pretty sweet though.
-Dattodude did you notice a difference from standard coils to bosch ones once you got them working
Posted on: 2009/11/12 11:55
From Sydney, Australia
Im using the bosch too, but i chucked a shedload of sheckles at autronic stuff to run it.
I would stick with the standard stuff unless you are willing to go all aftermarket.
Dont buy second hand stuff either, that will lead to heartache and carpet fires on the left side of your car.. Been there, before i did it properly.
Posted on: 2009/11/12 7:44
From Adelaide
picccc
jpg  9718_149570789881_706779881_3424707_1734291_n.jpg (68.15 KB)
6193_4afb7c5cd8caf.jpg 453X604 px
Posted on: 2009/11/12 3:10
From Adelaide
shmity used bosch.. thats what i use, havent missed a spark, #OOPS#ing easy to wire up also.. if you want i can try get some from my mate who works at motor traders, if not sprint auto parts are like 40bucks each.. so you buy 4 an then get leads.
nissansilvia has the wire diagram or google... ill post a pic of how mine are set up
Posted on: 2009/11/12 3:06
From Adelaide, SA
i have been told use ls1 coils but do they require aftermarket computer, to setup
Posted on: 2009/11/11 10:31
From Geelong, Vic
dazza, they straight wire up job?
also would you know anything about LS2 coils? apparently they are a fair bit smaller than LS1 coils (they must nearly be invisable)
Posted on: 2009/11/10 12:21
From perth
stock ls1 coils work well
Posted on: 2009/11/10 11:27
From Adelaide, SA
i ran them with cover on, on the track which is what i think destroyed them, but yer i have read same threads on bosch packs and not really 100% sure which is why i was hoping to clear it up
Posted on: 2009/11/9 10:41
