Re: Ca18det accelerator cable question
From SE Melbourne
I got a M6 bolt, drilled a hole in the middle of it, threaded the cut down CA18 cable through it and did up a nut of the bolt....bit agricultural but I think achieves exactly the same effect.
Posted on: 2009/12/15 10:33
Mildman, Datsunless
From Geelong, Vic
yeah i just got mine shortened and an adjustable end put on it
Posted on: 2009/12/14 11:27
From Mandurah, Western Australia
I used stock 1200 cable and fitted the CA18 end onto it. Obviously you need both cables and to re-solder the bit onto the end of the cable,
Posted on: 2009/12/14 10:55
From Melbourne, Australia
whats the typical solution to connecting up the accelerator able?
i saw the maddat cable but have people been using a standard cable with a modified bracket or something?
Posted on: 2009/12/14 10:52
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
